Favorite views do not show up in VR or standalones - Favorite views are now properly displayed.
Asset Library – Rotation Y gets stuck at 270–271 degrees when using mouse scroll wheel - Rotation now works smoothly.
Assigned shortcut disappears from settings UI - Assigned shortcuts now persist and are shown correctly across settings sessions.
Error when trying to edit a collaboration annotation - Annotations can now be successfully modified.
Veras - Inconsistent toolbar button style - Icon is now styled as all other icons on the toolbar
NewForma Connect - Orthographic camera can lead to loading issue - Orthographic camera can now be used properly with NewForma Connect functionality
Custom Asset Editor encrypts imported files when converting their format - Custom assets can now be successfully exported and imported again.
- VR - Changing seated/roomscale mode while moving keeps you moving forward after you've stopped holding the joystick - Changing modes now works properly.
- [Sketch up] Per-View Section Plane Visibility Is Determined By Native Global RenderingOptions - Section plane is now respected during the batch rendering of the first view.
- [Sketch up] View Not Reapplied After Batch Rendering - section planes are now visualized properly
- [Sketch up] Crash When Using Erase in The Ruby Console - the command now is executed properly
- [Sketch up] Black and White Images Are Not Correctly Shown in Material Editor - The preview now looks like the original image, same as when the texture is added via Enscape ME.
- [Vectorworks] Geometry Sync Breaks After Switching to Top/Plan View - Now geometry gets updated accordingly.
- [Rhino] Cannot create materials based on TIFF images - Now materials are successfully created
