This page provides information on the rendering styles in Enscape.
In the Visual Enscape Settings window, located under the Main Tab, a section named Style provides options to allow you to change the way that Enscape renders your projects. You will notice that the Style section contains, by default, a slider named Outlines and a drop-down menu that is named Mode. These ‘Modes’ allow a user to apply unique styles to their projects and produce a Maquette or Sciographic, Hatched Sketch, Watercolor rendered image style and lots more.
To access these options, make sure Enscape is running and then open the Visual Settings window using the associated button in the Enscape Viewport user interface, as shown highlighted to the right in the following screenshot.
Visual Settings window button
These options can be found at the top of the Visual Settings window. These options can be combined to create some interesting effects in your projects, as the modes change the way that your project is rendered in the Enscape window, and the outlines can help emphasize the geometric forms in a project. There are five Modes that can be chosen and be combined with the Outlines option. |
Style Settings |
White Mode
When White Mode is enabled all materials, apart from transparent ones, are then displayed in white color. |
White mode with Outline set to 0% |
White Mode with Outline to set 25% |
White mode with Outline set to 75% |
The Selective White Mode functionality is also visible in the White Mode. It allows users to exclude Enscape asset categories, or specific Enscape assets from White Mode. This feature enables users to highlight important geometry, materials, or scenery while keeping other elements in a simplified white state, focusing attention on defined aspects of the project. You can choose categories, individual asset groups, or you can manually pick assets to be excluded from the White Mode. |
Polystyrol Mode
Renders all surfaces like a real polystyrol material, whereby the sunlight is scattered through the thinned geometry. When this mode is selected, an additional setting appears named Transmission that determines how much light is transmitted through geometry. |
Polystyrol Mode and Transmission Slider |
Polystyrol mode with Transmission set to 0% |
Polystyrol Mode with Transmission to set 50% |
Polystyrol Mode with Transmission to set 100% |
You can see the effect of 0% Transmission in the following screenshots with 25% and 75% outlines applied.
Bump Maps
It’s also worth noting that bump maps will continue to be displayed when using White/Polystyrol Mode. |
Bump Map with no Mode enabled. |
Bump Map with White Mode enabled. |
Bump Map with Polystyrol Mode enabled. |
Light View Mode
This mode informs you as to how much light is hitting a surface and this is displayed as a heat map. It is worth noting that the Enscape Light View is not a professional or fully accurate light analysis tool, and is provided as an estimation only. |
Light View with Automatic Scale enabled |
There is also the Automatic Scale option which can be disabled. When disabled the minimum and maximum Lux scale can be set manually. |
Light View Mode with Automatic Scale disabled showing the manual adjustment sliders. |
In the Enscape Viewport, when Light View Mode is activated, there will always be a temp range indicator located to refer to which is located at the top of the Enscape viewport window:
Light View Temperature Gauge
This gauge will only be viewable in the Enscape window, and is not included in rendered images. |
You can also combine Light View mode with Outlines. |
Sketch Mode
This artistic visual mode recreates the rendering as pen or pencil sketches. This mode can be adjusted as black and white outlines, grayscale or as colored rendering. Outlines – Adjusts thickness of lines. Jitter – Modulates the distortion of lines within you sketch composition. Extended Lines – Controls the length and prominence of extended lines in your drawing. Transparent Glass – Enables to render objects behind glass with lighter colors. Hatched Shadows – Enhances the drawing by creating depth and form through hatched shadows. Pen – This is the default sketch style in black and white pen. Pencil – Transforms your sketch style to grayscale pencil. Colored Pencil – Customizes the style of the sketch by applying colors. |
Sketch Mode Settings |
Pen in Sketch Mode without Hatched Shadows |
Pen in Sketch Mode with Hatched Shadows |
Pencil |
Colored Pencil |
It is recommended to use this style for still renders to achieve best results. |
Exposure |
When you have Sketch Mode with hatching enabled, you can change the “Exposure” setting to affect the amount of shadows that are shown. You can also change the saturation and color temperature to affect your results. |
Saturation & Color Temperature |
Watercolor Mode
The Watercolor mode transforms your viewport into a real-time watercolor painting, simulating watercolor effects to create soft, blended look for your visualization. This mode comes with its own options to adjust the various color settings. Color Gradient – Affects the number of colors and hues. Surface Detail – Adjusts the level of texture detail on surfaces. Bleeding Effect – Controls color overlap between surfaces. Transparent Glass – Enable to render objects behind glass with lighter colors. |
Watercolor settings |
It is recommended to use this artistic visual mode for still renders to achieve best results.
Default Settings |
Increased Color Gradient |
Increased Bleeding Effect |
Both Color Gradient and Bleeding Effect applied |
When you have Watercolor Mode enabled, you can change the “Exposure” setting to affect the amount of shadows that are shown. |
Exposure |
Glass Tints in the Watercolor Mode |
