The Specular Render Element is an image that stores specular reflection (basically put, highlight) information calculated from the material's reflection value in the scene. Specular reflection is defined as the reflection of light from a surface in a single particular reflection, as opposed to a diffuse reflection, which is reflected at many angles. The brighter the area, the more highlight reflection the object exhibits in the render. If the Reflection Color parameter of a material is colored, the Specular highlights will be colored. This render channel can be used to enhance specular reflections; see the example.
UI Path: ||V-Ray|| > Render Elements > Specular (How to add a render element to a scene)
