This page provides information about the Corona Toon Material in Cinema 4D.
The following examples demonstrate the effect that individual Toon Material parameters have on the scene. Click on any image to view it at a higher resolution.
This example shows the effect of using the Toon Material in combination with the Outline Material.
Outlines are disabled
Outlines are enabled
This example shows the effect of using Diffuse Ramp and offsetting it.
Ramp Offset is -0.2
Ramp Offset is 0
Ramp Offset is 0.2
This example shows the effect of Interpolation. You can select different interpolation types from the dropdown menu available when you right-click on a 'knot' and select Interpolation of all Knots.
There is no Interpolation
Interpolation is linear
Interpolation is smooth
Interpolation is spline
This example shows the effect of using Specular Ramp and tweaking its Interpolation.
This example shows the effect of Anisotropy. The effect is mostly visible in the reflections of the apples.
Anisotropy is default
Anisotropy is hexagon
Anisotropy is square
Anisotropy is star
Anisotropy is textured
