This page introduces the Volumetric Grid Properties.
After the VRayVolumeGrid is created, its Properties can be accessed through several tabs when highlighted.
UI Path: ||Select VRayVolumeGrid|| > Properties Panel
Rollouts
The following tabs contain parameters for modifying the volume grid.
- Input tab - Provides controls for multiple frame input, timing of frames, and blending/smoothing of frames.
- Preview tab - Provides controls for how the volume grid effect is displayed in the viewport.
- Rendering tab - Provides controls for how the volume grid effect is rendered.
- Fire tab - Provides volumetric shader controls for the emissive color (fire) and the light emitted by the volume grid.
- Smoke tab - Provides volumetric shader controls for the diffuse (smoke) color and opacity.
