Official release
Date – Apr. 4, 2017
Download Build – 1.0
Key Features
  • Measurement of CPU and CUDA GPU V-Ray rendering performance
  • Benchmark.chaosgroup.com site section for comparing benchmark results against other hardware
  • Single executable that runs without Administrative privileges and without Internet connection
  • Free software - V-Ray license is not required
  • High DPI support
Known Issues
  • OS UI may be sluggish during GPU benchmark
  • GPU CUDA devices could be enabled/disabled from nVidia Control Panel only
  • If there is a proxy present, you should:
    1. LAN Settings > Bypass proxy server for local addresses - should be turned on
    2. Set environment variables HTTPS_PROXY and HTTP_PROXY before benchmarking
