This correction allows you remap the image colors with a Bezier curve. The control also allows you to save and load .acv curve files from Adobe Photoshop. Controlling the View Use the mouse wheel to zoom in and out of the curve view. Drag with the middle mouse button to pan. Controlling the Bezier Points Click on a point to select it. Draw a rectangle to select multiple points at once. Click and drag on a selected point or its tangents to move them. To add a new point, Ctrl+click on the curve. To delete points, select them and press Del, or alternatively Shift+click on a point. Once a point is selected, you can also use the input coordinates field in the upper left to modify its position.
This correction allows you remap the image colors with a Bezier curve. The control also allows you to save and load .acv curve files from Adobe PhotoShop. Controlling the View Use the mouse wheel to zoom in and out of the curve view. Drag with the middle mouse button to pan. |
