This page provides an overview of the VRayMtl and its parameters.
You can create a VRayMtl through the ||Content Browser|| > Add New > V-Ray > VRayMtl or from ||Content Browser|| > Add New > V-Ray > VRay Material Instance > Parent Material > VRayMtl.
Diffuse
Reflection
FresneIOR
ReflectionGloss
Refraction
To use it you must also set the Blend Mode in the Material Property Overrides to Alpha Composite. |
BumpTex
NormalTex
Selfillumination
We suggest when using SelfIllumination to set the Blend Mode in the Material Property Overrides to Opaque. |
Opacity
To use it you must also set the Blend Mode in the Material Property Overrides to Translucent or Alpha Composite. Due to Unreal Engine's limitation when using Translucent blending mode and Two Sided enabled, back faces on two-sided geometry may appear front. To resolve this when using Opacity Tex uncheck the Two Sided option. |
ClearCoat
To use it you must set the Shading Model in the Material Property Overrides to Clear Coat. |
VRay2SidedMtl
To use it you must set the Shading Model in the Material Property Overrides to Two Sided Foliage. |
