This page gives details on how to use a USB dongle in conjunction with the online licensing system.
Page Contents
The Online Licensing system allows you to use seats associated with your Chaos Group account easily from anywhere you can log into over the internet. If you also have a V-Ray USB License dongle attached to your workstation/server, you can utilize those available licenses within the online system.
Note that there might be some delays in detecting a dongle when it is plugged in. If however a dongle is not recognized at all by the system after plugging it in, try disabling and re-enabling the dongle subsystem.
Enabling your Dongle Licenses
You can Enable your USB dongle by clicking on the Enable Dongle button.
Once your USB dongle is enabled you will be able to see your dongle information.
If you need to upgrade your dongle please click the Upgrade and follow the instructions found on the Dongle Reprogramming page.
When using a dongle license connected to OLS you are only able to access the dongle licenses on the machine that the dongle is connected too.  You are unable to access dongle licenses over the internet on another machine logged into OLS.
