This page contains information about V-Ray's standalone OBJ GEO PLY to .vrmesh Converter.
This is a command-line utility that can be used to convert .ply, .obj, .bin, .geo, .bgeo, .hclassic, .bhclassic, .abc and .vrscene files to .vrmesh files for rendering with V-Ray through a V-Ray's Proxy Objects.
UsageUsing the following command converts the given .ply or .obj file and writes it to the given .vrmesh file. Note that you must specify the file extension, it will not be added automatically.
ArgumentsinputFile – Specifies the .ply .obj .bin .geo (.hclassic) or .bgeo (.bhclassic) .abc .prt or .vrscene input file name. The string may include wildcards. outputFile – Specifies .vrmesh file output name (extension must be specified). This string may not include wildcards. If this is not specified then the output is a file with the same name, but with the .vrmesh extension. If multiple input files are specified and <outputFile> is missing, then each input file will be written to a separate .vrmesh file. If multiple input files are specified and <outputFile> is also specified, all input files are sorted in lexical order and concatenated into one animated .vrmesh file. Options-verboseLevel – An integer value to determine the verbosity of the output. (0 - no output; 1 - errors only; 2 - errors and warnings; 3 - errors, warnings and informational messages; 4 - all output). The default is 3. -append – Appends the information as a new frame to the .vrmesh file. -smoothNormals – Generates smooth vertex normals. Only valid for .obj and .geo files; always enabled for .bin files. -smoothAngle – A floating point number that specifies the angle (in degrees) used to distinguish if the normals should be smoothed or not. If present it automatically enables the -smoothNormals flag. -flipNormals – Reverses the face/vertex normals. Only valid for .obj, .geo, .bin and .abc files. -flipVertexNormals – Reverses the vertex normals. Only valid for .obj, .geo, .bin and .abc files. -flipFaceNormals – Reverses the face normals. Only valid for .obj, .geo, .bin and .abc files. -flipYZ – Swap y/z axes. Needed for some programs i.e. Poser, ZBrush. Valid for .ply, .obj, .geo and .bin files. -flipYPosZ – Same as -flipYZ but does not reverse the sign of the z coordinate. -flipXPosZ – Same as -flipYPosZ but swaps x/z axes. -mapChannel <chanIndex> – Stores the UVW coordinates to the specified mapping channel (default is 1). Only valid for .obj and .geo files. When exporting a mesh that will be used in Maya, currently this must be set to 0 or the textures on the mesh will not render properly. -disableColorSetPacking – Only valid for .geo and .bgeo files; disables the packing of float1 and float2 attributes in vertex color sets. -materialIDs – Only valid for .geo and .bgeo files; assigns material IDs based on the primitive groups in the file. -materialIDs_splitGroups – Only valid for .geo and .bgeo files; assigns material IDs based on the primitive groups. These groups are split into different voxels/meshes and appear in visibility lists. -sortMaterialIDs – Only valid for .geo and .bgeo files; sorts the list of material IDs by the group name. Otherwise they are in the same order as they appear in the .geo/.bgeo file. -fps <fpsValue> – A floating-point number that specifies the frames per second at which a .geo or .bin file is exported, so that vertex velocities can be scaled accordingly. The default is 24.0. -previewFaces <numFaces> – Specifies the maximum number of faces in the .vrmesh preview information. Default is 9973 faces. -previewType <type> – Specifies the method used to generate a preview. clustering – Works very fast, but is less accurate. -facesPerVoxel <numFaces> – Specifies the maximum number of faces per voxel in the resulting .vrmesh file. Default is 10000 faces. -previewHairs <numHairs> – Specifies the maximum number of hairs in the .vrmesh preview information. Default is 500 hairs. -segmentsPerVoxel <numSegments> – Specifies maximum segments per voxel in the resulting .vrmesh file. Default is 64000 hairs. -hairWidthMultiplier <multiplier> – Specifies the multiplier to scale hair widths in the resulting .vrmesh file. Default is 1.0. -previewParticles <numParticles> – Specifies the maximum number of particles in the .vrmesh preview information. Default is 20000 particles. -particlesPerVoxel <numParticles> – Specifies maximum particles per voxel in the resulting .vrmesh file. Default is 64000 particles. -particleWidthMultiplier <multiplier> – Specifies the multiplier to scale particles in the resulting .vrmesh file. Default is 1.0. -mergeVoxels – Merge objects before voxelization to reduce overlapping voxels -velocityAttrName <name> – Specifies the name of the point attribute which should be used to generate the velocity channel. By default, the v attribute is used. -pointSize – If specified, turns on point cloud generation and specifies the smallest size of the points. Default is 0.0 (point cloud generation is disabled). -velocityOffset <offset> – Specifies that the starting position should be offset by a fraction of the velocity channel, f.e. -0.25. Only valid for .geo, .bgeo and .bin files. -mergeFiles – Merges all input files into one .vrmesh file. Input files are specified using wildcard. -mergeShaders – When merging files using -mergeFiles, this option merges all shaders with the same name into one shader. When merging .obj files, then the first found .mtl file in the directory is parsed to get the ordering of the materials. Alembic subdivision specific-subdivideAllMeshes – Subdivides all alembic polygonal meshes, not only subdivision objects. -subdivisionLevel – Alembic subdivision level. -subdivideUVs <value> – Specifies the subdivision of the mapping channels. Value 0 to skip map channel subdivision and 1 to apply it. -preserveGeomBorders – Skips the subdivision for all geometry borders. -preserveMapBordersMode <mode> – Preserves map borders mode. Mode "none" to subdivide all map borders. *.vrscene specific-vrsceneList – Shows a list of available Nodes in the .vrscene file. -vrsceneNodeName <name> – Node name inside the .vrscene file. Must be specified! -vrsceneApplyTm – Applies Node transform matrix to the mesh. -vrsceneVelocity – Generates velocity channel (used for motion blur). -vrsceneFrames start-end – Exports animation range. Generic-info – Shows information about the specified .vrmesh file. -frame <frameIndex> – Exports particular frame from the specified file. Combined with -info option it shows information about the specified frame from the .vrmesh file. Indices are 0-based. If this option is not specified, information is printed for each frame in the file. -oneFramePerFile – Exports each frame in separate file. -padding <padding> – Frame padding number between 1 and 10. Default is 4.
Note: These options can also be viewed from the command prompt by running the ply2vrmesh program without any parameters to see the description of these options. Notes
