File (*.vrscene) – Specifies the .vrscene file to load. Reload Scene – Reloads the scene file. Flip Axis – Controls which axis is used as a vertical - the Y or Z axes for the loaded vrscene. You can choose between: None – No changes in the axes are applied. Auto – It aligns the vertical axis of the vrscene with the vertical axis in the scene in cases where the vrscene was not exported from Houdini. Use the Auto mode when loading a USD file. Z-up to Y-up – Switches the Y and Z axes. Expand Primitives – When enabled, a Primitive Group is created for each object in the .vrscene file. In the case of vrscenes coming from Maya, for example, each Shape node generates a new Primitive Group. Expand All Primitives – When enabled, expands all primitives without hierarchy. Works only when Expand Primitives is enabled. Allow Unpacking To Polygons – When enabled, allows unpacking to polygons. Works only when Expand Primitives is enabled, and Use Preview Faces is disabled. |
