This page provides information on the V-Ray VRayClipper node.
VRayClipper is a geometric primitive that can be used to clip away parts of the scene with a defined geometry or a simple plane. It is a render-time effect and does not modify the actual scene geometry in any way.
The images on the right show a geometry before and after being clipped with VRayClipper.
Enabled – Turns the clipper effect on and off.
Gizmo Size – Specifies the viewport gizmo size.
Clip Mesh – Specifies the mesh VRayClipper uses to clip.
Operation – Determines how to use the mesh:
Intersection – Clips away anything that is outside the specified mesh; only render objects and parts of objects inside the specified mesh;
Subtraction – Clips away anything inside the specified mesh; only render objects and parts of objects outside of the specified mesh.
Camera Rays Only – When enabled, the clipper affects objects as they are directly seen by the camera, but they appear unchanged to reflection/refraction/GI rays.
Affect Light – Enables the clipper to also affect light sources.
Clip Lights Geometry – Enables the clipping of lights geometry (for example a mesh light).
Object ID – Specifies an Object ID number for the VRayClipper.
Use Object Material – Enables the clipper to use the material of each clipped object to fill in the resulting holes. When disabled, the material applied to the clipper object itself is used.
Set Material ID – When enabled, specifies a Material ID number to the VRayClipper.
Material ID – Specifies a Material ID number for the VRayClipper.
Exclude Mode – Specifies the effect of the Exclude list.
Exclude – Objects in the Exclude list are not clipped.
Include – Only objects in the list are clipped.
Exclude – Specifies an include/exclude list that allows you to select which scene objects to be clipped.
This example demonstrates how to use a defined meshes as Clipper Geometry to create detailed results.
Original Geometry Viewport
Clipper Mesh
The first image shows the original geometry, and the second - the cut geometry.
disabled
enabled
This example shows the effect of the Affect lights parameter.
disabled
enabled
