Enable – Enables the V-Ray Toon effect. See the Toon Effect example below. SilhouetteColor – Specifies the color of the outlines using a map. See the Line Color example below. Width – Specifies the width of the outlines using a map. Interior EdgesDisable Interior Edges – When enabled, uses the same Color/Width parameter values for both silhouette and interior edges. Adjust Interior Edges – When enabled, allows you to specify the color and width of the interior edges. Color – Specifies the color of the cartoon line at interior edges. Width – Specifies the cartoon line width of interior lines. ControlsOpacity – Specifies the opacity of the outlines using a map. Normal Threshold – Determines when lines are created for parts of the same object with varying surface normals (for example, at the inside edges of a box). A value of 0.0 means that only 90 degrees or larger angles generate internal lines. Higher values mean that smoother normals can also generate an edge. Don't set this value to pure 1.0 as this fills curved objects completely. Interior Threshold – Determines when outlines are created for overlapping parts of one and the same object. Lower values reduce the internal overlapping lines, while higher values produce more overlap lines. Don't set this value to pure 1.0 as this fills curved objects completely. Silhouette Threshold – Determines when outlines are created for overlapping parts of one and the same object. Lower values reduce the outer overlapping lines, while higher values produce more overlapping outer lines. |
