Multiple Scattering – Selects the type of algorithm: Prepass-Based Illumination Map – This algorithm approximates sub-surface scattering by pre-computing an illumination map on the surface of the object; this map is built using V-Ray's prepass system (the same one used for the irradiance map and interpolated glossy reflections/refractions). The advantage of this method is that it is quite fast, since the illumination map is only computed for the portions of objects that are visible to the camera. Also, the amount of calculations is proportional to the screen space taken up by the object. A disadvantage is that no information is generated for parts of objects outside the screen, which may lead to incorrect results for objects which are only partially visible. Since the distribution of the samples depends on the camera position, flickering is possible in animation. Finally, objects that are far away from the camera may be sampled insufficiently, leading to incorrect results. Object-Based Illumination Map – This algorithm also approximates sub-surface scattering by pre-computing illumination on the object's surface; however the points are distributed directly on the surface on the object with a specified density. This method avoids the problems of flickering and insufficient sampling for far-away objects, however it may calculate a lot more illumination points that are strictly needed to render the image. Raytraced – This method uses raytracing to distribute points on the object's surface. It does not require pre-computation and is suitable for use with the Progressive image sampler. The only disadvantage of this method is that it can introduce noise in the image if the raytraced samples are insufficient. Scatter Textures – Controls whether the textures for the sub-surface scattering layers are taken into account when computing the scattering. Turning this option may lead to more accurate results, but adds quite a bit of render time. For more information, see the Raytraced Scatter Textures example below. Scatter GI – When enabled, GI is taken into account when calculating multiple scattering. Otherwise, GI is approximated as if the surface is diffuse. Turning this option on leads to more accurate results when using GI, but may slow down the rendering. Rate – Determines the resolution of the prepass used to compute the helper illumination map when Multiple Scattering is set to Prepass-based Illumination Map. Larger values produce more accurate results but take longer to compute. For example, a value of -1 means that the prepass is done at half the image resolution; 0 means that the prepass is done with the full image resolution etc., 1 means twice the image resolution, etc. Prepass ID – Different skin materials with the same Prepass ID value share the same illumination map. This is useful if different materials are applied to parts of the same object, but a smooth transition between them is required. A value of 0 means that the particular VRaySkinMtl material uses its own illumination map. Interp. Accuracy – Controls the quality of the approximation of the multiple scattering effect when Multiple Scattering is set to Prepass-based illumination map or Object-based illumination map. Larger values produce more accurate results but are slower to render. Lower values render faster, but too low values may produce blocky artifacts on the surface. Auto Density – Tells the material to attempt to automatically determine the required density of the illumination samples when Multiple Scattering is set to Object-Based Illumination Map. Note: currently this option does not work very reliably. Samples / Unit Area – When Multiple Scattering is computed with an Object-based illumination map, this parameter determines the number of illumination samples per unit area of the object. Larger values produce more samples and more dense sampling that captures surface illumination details better, but may slow down the rendering and take more RAM. Lower values render faster, but too low values may not capture the surface illumination accurately leading to artifacts. The Preview Samples option can be used to visualize the position of the samples. Surface Offset – When Multiple Scattering is set to Object-Based Illumination Map, specifies a small distance above the surface of the object where the illumination is actually computed, in order to avoid "surface acne" artifacts. Preview Samples – Can be used to visualize the samples in the Object-based illumination map. Max Distance – (available when the Preview Samples option is enabled) Specifies how large the visualized samples are. Background Color – (available when the Preview Samples option is enabled) Specifies the background against which the samples are visualized. Samples Color – (available when the Preview Samples option is enabled) Specifies the color of the individual samples. |
