Texture – Specifies a texture that is combined with the value. Custom Value – Specifies a scalar value. Texture / Value Blend – Specifies a texture multiplier that is used to blend between the value and texture. Result Multiplier – Specifies a multiplier for the result. Texture Clamp – When enabled, the output is clamped to 1 from above. When disabled, the output is always clamped to 0 from below. |
