This page provides information on the V-Ray MtlVRayMesh
Page Contents
The V-Ray Proxy Material is used to append materials to the V-Ray Proxy geometry.
UI Path: ||shop Network|| > V-Ray Material node > V-Ray > Material > V-Ray Proxy Material
The V-Ray V-Ray MtlVRayMesh node provides inputs for connecting materials to a V-Ray Proxy.
VRayProxy SOP – Use this parameter to point to the V-Ray Proxy in the scene. Once it is selected, the V-Ray MtlVRayMesh node will create inputs for every shape or object in the proxy. Materials can then be connected to them.
