Enable – Enables the rendering of the channels included in this preset group. All of the Beauty Render Elements share the same Channel options: Active – Enables the render of the channel. Denoise – Enables the render element's denoising, provided the Denoiser render element is present. Consider for AA – By default, the Image sampler applies AA based on the RGB image. When this option is enabled, the Render Element is considered for AA. Filtering – When enabled, it applies the antialiasing filter to the render element. Color Mapping – Applies the default color mapping options to this render element (Reinhard).
