To install V-Ray Standalone, make sure your Windows account has administrative privileges and double-click the installer to run it: To complete the installation follow these steps:
1. You are presented with the V-Ray licensing agreement. Please take a moment to review the agreement. Tick the I accept the Agreement checkbox. Click on Install to proceed with a standard V-Ray installation. If you need to customize the installation, click on Advanced.
Directories At this step you can adjust the installation directory. Please check if the default directory is correct.
Help make V-Ray even better – Participate in the improvement decisions for future version of V-Ray. No intelligence property is violated when agreeing to participate in the feedback program. Chaos does not gather scenes, assets, materials, etc. What Chaos receives is user preferences on just a few key render settings and the resulting render times. The point of this feature is to improve V-Ray's performance and the user experience. For more information, see the Chaos Telemetry page.
Licensing Here you specify whether the V-Ray license server runs locally or on a separate machine (remotely). See the appropriate tab for your choice.
Migrate data during installation – When enabled, the installer transfers all of your settings made with older versions of the License Server, such as enabled dongle subsystem, proxy settings, etc. Disabling this option installs the License Server with all settings at their defaults and any custom settings from the previous installation are lost. Add firewall exception – Enabling this option allows the default licensing port (TCP 30304) in the firewall. If you disable it at this step, you need to manually add firewall exceptions later.
NOTE: If you choose this option, you need to then install the license server on your machine. You can find more information on the License Setup page. |
Once you are ready, click Install or Continue. |
2. The installer proceeds to uninstall any previous versions and install V-Ray Standalone. If the installation is successful, the following window opens.
Click on Done. |
To install V-Ray Standalone in Linux, follow these steps:
1. Open a console, navigate to the folder and use the full name of the installer to start it. It should look like this: /username/Downloads/V-Ray/vraystd_adv_61002_centos7_clang-gcc-6.3 |
2. Follow the instructions of the installer:
2.1 You are presented with the V-Ray licensing agreement. Please read carefully the agreement! Tick the I accept the Agreement checkbox. Click on Install to proceed with a standard V-Ray installation. If you need to customize the installation, click on Advanced.
Licensing Here you specify whether the V-Ray license server runs locally or on a separate machine (remotely). See the appropriate tab for your choice. Migrate data during installation – When enabled, the installer transfers all of your settings made with older versions of the License Server, such as enabled dongle subsystem, proxy settings, etc. Disabling this option installs License Server with all settings at their defaults and any custom settings from the previous installation is lost. Add firewall exception – Enabling this option allows the default licensing port (TCP 30304) in the firewall. If you disable it at this step, you need to manually add firewall exceptions later. |
Click Install or Continue to proceed. |
2.2 The installer proceeds to uninstall any previous versions and install V-Ray Standalone. If the installation is successful, the following window opens.
3.Click on Done.
It may be necessary to log out and log in again so that some of the changes to the environment variables made by the installer can take effect. |
To install V-Ray Standalone on macOS, extract the V-Ray installation file in an appropriate folder and double click to run it.
1. You are presented with the V-Ray licensing agreement. Please read carefully the agreement! Tick the I accept the Agreement checkbox. Click on Install to proceed with a standard V-Ray installation. If you need to customize the installation, click on Advanced.
Licensing Chaos products cannot run on your machine without an active license. Here you specify whether the V-Ray License Server runs locally or on a separate machine (remotely). See the appropriate tab for your choice. Migrate data during installation – When enabled, the installer transfers all of your settings made with older versions of the License Server, such as enabled dongle subsystem, proxy settings, etc. Disabling this option installs License Server with all settings at their defaults and any custom settings from the previous installation is lost. Add firewall exception – Enabling this option allows the default licensing port (TCP 30304) in the firewall. If you disable it at this step, you need to manually add firewall exceptions later. |
Click Install or Continue to commence the installation. |
Click on Done.
