Once ready with the settings configuration, go to Render Movie Settings. From the Capture Settings panel > Output Format select the V-Ray animation export option. Now, set the VRScene export options. In this example, we want to autosave the rendered frame, and for the purpose of the tutorial - show it in the V-Ray Frame Buffer. Select the appropriate image output format. You can double check if the Output Directory shows the right path. When Render in VRay Frame Buffer and Auto Save Rendered Frame are set to true a .vrscene file with the name specified in Filename Format will be generated. If Output Directory in VRScene Export Options is empty then the frames will be saved in the directory of the .vrscene.
Press the Capture Movie button to begin the export. In the final version of the animation other actors were added in the sequencer and had their transformations animated with the steps mentioned above. |
