- Cannot use a Bullet Solver body in the Body Force
- Cannot create a Quick Setup over Bullet Solver bodies
- When a Quick Setup preset is added to an object, you can add another source to it
- Could not replace a geometry in a Source once it's used for a Quick Setup preset
- Alembic files cannot be added to the sources through the button
- After simulating some frames and then closing Maya without saving, caches are not deleted
- Undo command while simulating freezes Maya
- Changes made by Reset to Defaults button in the Volumetric Settings do not participate in the undo/redo history
