Particle Systems | part_systems – Specifies the particle systems that will be shaded. Mode | mode – Sets the shading mode. For more information, see the Mode Example below. Bubbles – Each particle is shaded as a spherical, transparent, reflective foam bubble. Surfaces of bubbles that intersect one another are visible inside the bubbles. If you get flickering or noisy renders of tightly packed masses of foam such as beer heads, you should switch to Cellular mode. Otherwise, in animation, pairs of bubbles would appear with one bubble completely in front of another in one frame, and completely behind on the next frame, once the bubble's center goes behind the other bubble's center. This would cause abrupt changes in the overall look of the foam mass in animation. Cellular – Similar to Bubble mode, but replaces intersecting walls between bubbles with a curved wall. The degree of curvature is determined by the Pressure variation parameter. This mode is about twice as slow as simple Bubbles but is suitable for close-up foam. Splashes – Each particle is shaded as a spherical, opaque, reflective droplet. Surfaces of droplets that intersect one another are not visible. Note that when a Liquid Simulator is connected, particles will not render as Splashes when they are inside the liquid volume of the Liquid Simulator. This is because Splashes represents small liquid droplets used to add more detail to the Liquid mesh, so it does not make sense to render them underwater. Points – Particles are shaded as flat discs, each the size of one pixel by default. This mode is faster than Bubbles, Cellular, and Splashes and thus is suitable for large scale foam and splashes over a large surface, such as an ocean surface. This mode is also suitable for rendering non-foamy fluids such as smoke or ink. Because the points are pixel sized, moving the camera away or decreasing the render resolution will make them appear denser, while moving the camera in closer or increasing the render resolution will make the particles look more scattered. Note that Point mode does not do reflections or refractions like the Bubbles, Cellular, and Splashes, so the particles will look diffuse and sometimes darker if you render them next to strongly reflective materials. Fog – Each particle is put into a grid and the smoke shader is used to visualize the grid's content. This mode is an alternative to Point mode. Subgroup | subgroup – The Particle Shader can skip rendering some particles depending on the selected condition: All – All the particles are rendered. Under Water – Only particles inside the mesh volume of the connected Liquid Simulator are shaded. Note that when Mode is set to Splashes, particles will not render with the Under Water subgroup as it would produce no effect to render liquid drops submerged in the liquid surface. This is because splash particles would die when they merge back into the liquid volume - see FLIP Particles Life Cycle. Above Water – Only particles outside the mesh volume of the connected Liquid Simulator are shaded. Below Size Threshold – Only particles smaller than the Size Threshold value are rendered. Above Size Threshold – Only particles larger than the Size Threshold value are rendered. Constant Color | color – Specifies the particle color. Color From RGB Channel | colfrompartchan- Allows you to shade the particles based on the simulated RGB Channel. This option will extract the color information and use that as the color for the particles. This will produce a natural looking result, as each particle carries its own RGB data that is read directly. This option is also faster than the alternative approach, which would be using a Particle Texture in the Color From Tex map slot below.
Note that using this option will override the Constant Color. However, using a texture map with the Color From Tex parameter below will override the Color From RGB Channel parameter. |
Only Phoenix Particles are supported for this option. Also, currently it will only use the RGB Channel. In addition, keep in mind that the RGB Channel might not be available in all of the Particle Systems that you have selected for your Particle Shader. |
Color From Tex | usecolormap, colormap - Allows you to connect a texture to shade the particles based on a selected Particle Channel. Works both with regular 3ds Max textures and the Phoenix FD Grid Texture and Particle Texture. If you are simulating the RGB channel, you can use the Grid Texture or Particle Texture to extract the color information and use that as the Color Map for the particles. This will produce a natural looking result, as each particle carries its own RGB data that is read directly. If using a regular 3ds Max texture (e.g. a Checker map), editing the mapping coordinates of the texture may be necessary. Furthermore, when using a static 3ds Max texture, the particles may 'swim' through the color values of the texture, producing an unnatural result.
Note that when using a Particle Texture, its Particle Area Radius is very important for the rendering speed - the larger the Particle Area Radius, the slower the render. It's best to start with a very small Particle Area Radius - this way the particles would render with black edges. Keep increasing the Particle Area Radius until the black edges are no longer visible, and this way you would get the best render speed for your setup. |
If you plug a regular 3ds Max texture, the Explicit Mapping option won't work well for you as the Particle Shader contains no 'real' geometry that can be UV-mapped. Instead, the bounding box of the particles is used for the texture mapping and sampling. For more information on texture mapping in Phoenix, please check the Texture mapping, moving textures with fire/smoke/liquid, and TexUVW page. |
Note that using the Color From Tex parameter will override the Constant Color and the Color From RGB Channel parameters. |
Diffuse Multiplier | difmul – Provides an additional option to multiply the color brightness. Size Multiplier | szmul – Acts as an additional parameter for controlling the bubbles/splashes size, independent of their particle system. This parameter can be animated to reduce the size of the rendered particles over time. If the PA (Particle Age) option is enabled, the animation is applied on a per-particle basis rather than acting simultaneously over the entire particle group. The value for this parameter is not set as a constant but instead is affected by the Size variation and Size distribution parameters. This introduces randomness in a particle system where all particles have the same size. PA | szmul_pa – When enabled, animation of the Size Multiplier parameter is evaluated individually for each particle. The Age channel of individual particles is treated as if it is the Timeline itself, and animation applied to the Size Multiplier is evaluated over it. Therefore, the Size Multiplier animation is applied to each particle, starting at its time of birth. For example, animating the Size Multiplier to go from 1 to 0 over Timeline frames 0 to 30 will individually scale down each particle during the first 30 frames of its birth. Conversely, when this option is disabled, the Size Multiplier animation will treat the particles as a collection of points, and will scale them simultaneously, regardless of their current age. For example, animating the Size Multiplier to go from 1 to 0 over Timeline frames 0 to 30 will simultaneously scale all particles in the simulation over the first 30 Timeline frames, and none will be visible on frame 31. Note that the particle Age Channel export must be enabled from the Output rollout of the Phoenix Simulator. Size Addend | szaddend – Add this to the size of the particles in order to make them larger, or smaller if a negative value is used. Unlike Size Multiplier which would scale all particles proportionally, Size Addend adds a fixed number to all particle sizes. If both Size Multiplier and Size Addend are used, the Size Multiplier scales the sizes first, and then the Size Addend is added. Size Variation | szvar – Adds randomization to the Size Multiplier so that different particles are scaled differently. The higher the variation, the larger the difference between the smaller and the larger sizes will be. Size Distribution | szdist – Controls the number of bubbles that change size as a result of the Size Multiplier. When this value is set to 0, all particle sizes will simply be multiplied by the Size multiplier. When this value is greater than 0, some particles will be multiplied by a higher value, and some will be multiplied by with a lower value. Setting this value to 1 ensures that an equal amount of particles will be made larger as those that remain smaller. Increasing this parameter will produce many smaller particles and fewer big particles. Size Threshold | sizelimit – If the particle count is very high and most particles are indiscernible from the camera position, using separate shading techniques for large and small particles will give better results. This parameter works in combination with the Subgroup parameter for this purpose. When the Subgroup parameter is set to Above Size Threshold or Below Size Threshold, the shader only renders particles that satisfy the condition. Use a second Particle Shader object to render the rest of the particles by setting the opposite condition. This makes it possible to have different shading for big and small bubbles or droplets. Vertical Offset | vertoffs – Shifts the particles along the up axis. Can be used in fish tank simulations for custom alignment of the particles floating on the liquid surface. This can be helpful when the camera is close to the water and there is a visible particle offset from the water surface. Count Multiplier | cntmul – Increases or decreases the number of particles for rendering. When the value is below 1, the particle count decreases, skipping the particles randomly. When the value is above 1, new particles are created and placed randomly among the original ones in a way that attempts to preserve the group's overall shape. Note that you have to export the particle ID channel if you want to render animation, otherwise the particles would start appearing and disappearing in different places during the animation. Liquid Simulator | useliquid, liquid – Allows a link to the simulator that produced the shaded particles. Currently, only Phoenix objects Fire Smoke Simulator and Liquid Simulator can be set as the Liquid Simulator. When set, the shading of the particles changes when they are inside the liquid volume, as if they are underwater, allowing the use of the Subgroup option. Also, if the simulator uses Displacement, connecting it to the Particle Shader will displace the particles as well. displ_fade_from_liq – Script parameter that enables suppression of the the Particle Shader's displacement, using the liquid mesh of a Phoenix Simulator. The option is disabled by default. displ_fade_from_liq_dist – Script parameter which controls how far from the liquid surface the displacement is completely suppressed. The distance is in voxels. Disable Liquid Shadows | nolqshadows – When enabled, the fog color of any mesh surrounding underwater particles will not contribute to their lighting. The particles will still be tinted by the fog color when looked at from the camera, but the shadows they receive will be bright and unaffected by the fog color of the liquid mesh. Use Ocean Border Fade | flatatoceanbord - When enabled, in Ocean Mesh mode, particle height will fade towards the ocean level like the ocean vertices do. Note that the viewport preview does not reflect the Use Ocean Border Fade option currently. |
Cutter Geometry | useGizmo, gizmo – When enabled, only the volume inside the provided geometry is shaded. If the normals are inverted, the volume outside the geometry is shaded. Note that the Cutter Geometry will not work when Render as Geometry is enabled. Invert Cutter | invgizmo – When enabled, shading is applied outside the provided geometry. This is not the same as a Cutter with inverted geometry because any rays that do not intersect the Cutter will be shaded as well. Render as Geometry (V-Ray) | geommode – This method may be needed when rendering using V-Ray. Produces procedural geometry that contains multiple transparent layers. - When Render as Geometry is enabled, the Approximate and Approximate + Shadows settings for the Scattering parameter are not supported.
- When Render as Geometry is disabled, the Particle Shader is rendered as a volumetric, which is faster, but does not export deep images and many V-Ray render elements such as velocity, multi matte, zdepth, etc. For a complete list of the supported Render Elements in both Volumetric and Volumetric Geometry mode, please check the V-Ray Render Elements Support page.
- When Render as Geometry is disabled, overlapping Particle Shaders would blend correctly, but would not be able to blend together with other volumetric effects such as VRayEnvironmentFog, VRayAerialPerspective, etc.
Note that if Render as Geometry is disabled and you render particles below an ocean surface, you might also need to place a geometry that would serve as a bottom for the ocean. This would be needed only when rendering the ocean with a material that uses fog color. Since the particles and the fog of the material are both volumetric effects and are handled differently than meshed geometry, the volume of the ocean liquid must be closed off with another geometry, such as geometry for the bottom. Otherwise the renderer would not be able to determine if the particles are inside of the fog, or entirely behind it and they might render very dark and cause flickering or other undesirable effects in animation. When Render as Geometry is enabled, the renderer would be able to correctly render the particles with respect to the fog even without a closing geometry. |
Motion Blur | moblur – Controls the motion blur effect. From Renderer – The current renderer's own motion blur setting is used. Force on – The content is rendered with motion blur regardless of the global setting. Force off – The content is rendered without motion blur regardless of the global setting. Motion Blur Mult. | velmult – Can be used to make the motion blur effect stronger or weaker. This value can also be negative and would change the motion blur direction. It would also affect the V-Ray Velocity Render Element, even if motion blur is disabled. To render particles simulated by Phoenix with Motion Blur, you need to enable the Particle Velocity channel export for each particle system (Foam, Splashes, Mist, Drag, etc.) from the Output → Output Particles rollout of your Simulator. Otherwise, if rendering particles from other plugins or software packages with Motion Blur, they must have a velocity channel. |
Scattering | scattering – Controls how the light rays are scattered inside the particle volume. Ray-traced (GI only) – Enables physically accurate scattering of light rays. This mode produces the most realistic results but it's the slowest to render. It requires V-Ray with enabled Global Illumination, otherwise the rendered result would be the same as if the option is Disabled. The Diffuse Multiplier does not affect the rendering in this mode. Disabled – Disables scattering. The Diffuse Multiplier value can be used to correct the brightness because without light scattering the particles would generally render darker. Approximate – Uses an approximate formula which is faster than Ray-Traced scattering and produces good looking results. This option is not supported when Render as Geometry is enabled. Approximate+Shadows – Same as Approximate, but also affects the strength of shadows over the scene geometry. This option is not supported when Render as Geometry is enabled. Volume Light Cache | lightcache – Enables light caching, which can speed up bucket rendering considerably. - This option refers to the internal Phoenix Light Cache, which is unrelated to the V-Ray Light Cache.
- This option is ignored when using V-Ray GPU or Corona. It works with V-Ray CPU and Defscanline.
- When using V-Ray Progressive Rendering, the Volume Light Cache option might slow down rendering startup or the overall render speed.
- This option might produce artifacts when the particles are very dense.
- This option might produce artifacts when objects cast shadows through the particles.
- This option will consume additional memory, so beware of high RAM usage when rendering many particles.
- Some V-Ray render elements might not work when Volume Light Cache is enabled. Please consult this table.
Light Cache Speedup | subred – [V-Ray specific] [Valid only when Volume Light cache is enabled] Reduces the quality of the Volume Light Cache and increases the rendering speed. You can increase this and gain render speed as long as you don't start getting artifacts and excessive flickering in animation. Note that when using complex lighting with many light sources or dome lights with HDRI maps, combined with Bubbles, Cellular or Splashes mode rendering with Highlights enabled, increasing this option will cause the highlights to jitter over the surfaces of bubbles and this might cause flickering or noise in animation. Load preset – Allows you to load a preset (.tpr). Save preset – Allows you to save the current settings as a preset (.tpr file).
