This page contains information about the V-Ray Sampler Texture utility.
||shop Network|| > V-Ray Material > V-Ray > Texture > V-Ray Sampler
Although the TexSampler node does not contain any inputs, it provides a wide variety of outputs.
point – The sampled point.
pointReference – The shading point in reference space.
pointObject/Camera – The sampled point in object/camera space.
normal – The surface normal for the sampled point.
normalReferece – The smooth normal in reference space.
normalCamera/Object – The surface normal for the sampled point in object/camera space.
bumpNormal – The bump normal for the sampled point.
bumpNormalCamera/Object – The bump normal for the sampled point in object/camera space.
gnormal – The geometric normal for the sampled point.
view_dir – The view direction.
frame_time – The current frame (image) time.
ray_time – The ray time between the motion blur interval.
facing_ratio – Returns a number between 0 and 1 that specifies if the sampled point is facing towards or away from the camera.
material_id – The material ID for the sampled point.
flipped_normal – Specifies which side of the surface is sampled.
cameraNearClipPlane – The camera near clipping plane, calculated from the scene bounding box and the camera transform in the frame data.
cameraFarClipPlane – The camera far clipping plane, calculated from the scene bounding box and the camera transform in the frame data.
uvCoord – The UV coordinates for the sampled point.
rayDirection – Returns a vector from the sampled point to the camera position.
pixelCenter – The location of the pixel in the final rendered image that corresponds to the sampled point.
tangentUCamera – The surface tangent in the U direction for the sampled point.
tangentVCamera – The surface tangent in the V direction for the sampled point.
ray_depth – The ray depth.
path_length – The path length.
object_id – Returns the object ID for the object at the sampled point.
parent_object_id – Returns the object ID for the parent object of the sampled point.
velocity – The velocity of the sampled point.
speed – The speed of the sampled point.
random_by_renderID – Allows random colors or textures to be assigned to several objects according to each object's render ID.
random_by_polyShell – Allows random color or textures to be assigned to multiple polygon shells that have been combined into a single object.
UV Name – Specifies the name of the UV channel that will be used for sampling.
UV Index – Specifies the index of the UV channel that should be used for sampling when there is no applicable UV set name.
