Frame range and Frame step parameters are available only for the Animation output type. Those parameters are especially useful if you have failed frames. |
Frame range – Specifies a frame range to be rendered. You can specify non-sequential animation frames, e.g. 1-3,7,9,12-15. Frame step – Specifies a frame step in the frame range for rendering. For example, writing 8 in the Frame step box, will render every eight frame, hence the eight, the sixteenth, the twenty-fourth, etc. Note that the first frame is always rendered.
These filter buttons allow you to select only certain frames. All – If the parent animation scene has more frames submitted than rendered, it selects all of them to be rendered in the clone job. Uncompleted – Selects all frames which haven't completed rendering - failed, stopped, paused. Previous – Selects only the rendered frames from the parent job. Remaining – Selects all submitted, but not rendered frames (e.g. used Frame Step option or a frame range). For example, if you submitted 100 frames, but rendered every 10th frame, the Remaining filter adds 1-9, 11-19, ..., 91-99 frames. |
