The video below shows how to export a Phoenix FD cache to an Alembic file.
<iframe width="960" height="540" src="https://www.youtube.com/embed/egJMEoJjZFI" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Set Phoenix FD Simulator → Rendering roll-out → Mesh sub-roll-out → Mesh Type: Maya Mesh (not suitable for Ocean).
Double-check to make sure the Velocity Color Set field at the bottom of the Mesh roll-out is set to velocity.
Select the liquid mesh and go to Cache → Alembic Cache → Export Selection to Alembic (option box).
From the Alembic Export Options dialog, make sure Write Color Sets is enabled under the Advanced Options roll-out.
This video shows how to set the output format to OpenVDB and import the cached simulation inside of a V-Ray Volume Grid.
<iframe width="960" height="540" src="https://www.youtube.com/embed/_Fqa10NYsmg" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
Click the Phoenix FD Simulator → Output roll-out → '...' button next to the Simulation Save Path option.
Select Browse and navigate to a preferred folder. Set the File Name option and choose OpenVDB Cache from the Files of Type drop-down.
Start the simulation as usual. The output cache files are now OpenVDB instead of AUR.
