In order to produce correct Render Elements, Simulator needs Render Mode to be set to Volumetric Geometry with V-Ray Next and V-Ray 3.
In order to produce correct Render Elements, Particle Shader needs Render as Geometry to be enabled with V-Ray Next and V-Ray 3.
Please note that Particle Shader rendering is currently not supported with V-Ray GPU.
Keep in mind that V-Ray Next or V-Ray 3 Adv. CPU produce correct results with Progressive sampler for Render Elements only when Enable Filtering is on.
List of supported V-Ray Render Elements
Render Element
V-Ray Next/V-Ray 3 Adv.
Fire/Smoke
V-Ray GPU Next
Fire/Smoke
Particle Shader
Additional Notes
Lighting
Raw Light
Total Light
Raw Total Light
Shadow1
Raw Shadow1
GI
Raw GI
Self Illumination
LightSelect
Sampler Info1 Using V-Ray Next or V-Ray 3 Adv. CPU - this Render Element will work correctly only with Bucket sampler and Enable Filtering is off.
Z-depth1 Using V-Ray Next or V-Ray 3 Adv. CPU - this Render Element will work correctly only with Bucket sampler and Enable Filtering is off.
Normals1
Velocity1
Diffuse
Multi Matte
Footnotes
1
- Requires
Phoenix FD 3.12 and V-Ray Next update 1 nightly 28798 (18th December 2018) builds or newer.
