VFH_ROOT /mnt/HQRepository/vray_lin VRAY_APPSDK `chs("var_value0")`/appsdk VRAY_OSL_PATH `chs("var_value0")`/appsdk/bin VRAY_UI_DS_PATH `chs("var_value0")`/ui VFH_HOME `chs("var_value0")`/vfh_home VRAY_FOR_HOUDINI_AURA_LOADERS `chs("var_value0")`/vfh_home/libs VFH_PATH `chs("var_value0")`/vfh_home/bin:`chs("var_value0")`/appsdk/bin:`chs("var_value0")`/vfh_home/libs PATH `chs("hq_hfs")`/bin:`chs("var_value0")`/vfh_home/bin:`chs("var_value0")`/appsdk/bin:`chs("var_value0")`/vfh_home/libs HOUDINI_PATH `chs("var_value0")`/vfh_home:& LD_LIBRARY_PATH `chs("hq_hfs")`/dsolib:`chs("var_value0")`/appsdk/bin:`chs("var_value0")`/vfh_home/libs: HOUDINI13_VOLUME_COMPATIBILITY 1 HDF5_DISABLE_VERSION_CHECK 1 |
