The default preview mode that displays the individual content of each cell. All enabled channels are drawn if their content is between the corresponding thresholds. Only The Overlap Of – When enabled, all channels in a cell must meet the selected threshold conditions to visualize the cell.
Temperature – Enables the representation of the temperature.
As fire – When enabled, the natural color of a hot black body is used for coloring the temperature. Otherwise, the color ramp is used. Smoke – Enables the representation of the smoke. Fuel – Enables the representation of the fuel. Velocity – Enables the representation of the velocity. Velocity Streamlines – Traces the velocity field of the cache files to generate a streamline preview. Rainbow Color Curve – Represents the Velocity Streamlines in rainbow colors, where red is the fastest, green is medium speed and blue is the slowest. Streamlines Length – Signifies the maximum length of each streamline in the preview. Adjusting the value will provide you with a guide/preview of the velocity field's motion. The Line's length is measured in voxels and at the lowest setting, the Streamlines will be no larger than a voxel. Viscosity - Enables the representation of the viscosity channel. RGB – Enables the representation of the RGB channel. Auto Range – When enabled, automatically adjusts the preview ranges of visible channels for the current frame so that important data is always visible and the preview is always quick.
