VRay Render Mask Property Overview
VRayRenderMask property is designed for use only when Render mask mode in VRay Options/Image sampler (AA) tab is set to Render Mask Property. With this property you can mark only objects from the scene that you want to be re-rendered. In order to apply the VRayRenderMask property, you need to select the desired object(s) and from Render menu to choose Get>Property> VRay Render Mask. |
