Set the volume of the Grid as shown in the example. The grid is shown in purple color. Set its x, y, z respectively to 48, 157, 79, the Scene Scale to 1.0, and Cell size to 1.0 cm. Enable Adaptive Grid (based on Smoke) and set Extra Margin to 5, so the grid would be able to expand and accommodate the growing smoke. Also, enable the Maximum Expansion option and set the values as shown ). Adaptive Grid allows you to save memory and simulation time as the simulation grid is not set to its largest extents at the very beginning and gradually. The exact position of the Simulator in the scene is [ 44, -41, 96 ]. |
