VRScene Name – Specifies the name of the generated .vrscene file. Export VRScene Path – Directory where the .vrscene file is saved. Default directory is <ProjectPath>\Content
Compress – Compresses geometric information thus making the resulting .vrscene file smaller. NEW Export Selected Only – Exports only selected actors in the scene to a .vrscene file. Option will be ignored when Light Bake option is enabled. Light Bake – Exports separate .vrscene files for every light map atlas. The number of generated .vrscenes depends on: - Actor Light Map resolution
- Atlas resolution
- Actor count in the level
