This page provides information on how to get V-Ray up and running.
Setting up V-Ray for 3ds Max comprises of few steps: downloading, installing and licensing, and then setting V-Ray as the renderer inside 3ds Max.
System RequirementsCheck if your hardware matches the minimum requirements to run V-Ray. |
Try V-RayIf you are a trial user, check how to download and install V-Ray for 3ds Max. |
Install V-RayIf you are an edu/commercial user, check how to download and install V-Ray for 3ds Max. |
License SettingsFind some detailed information about Licensing and configuring license settings. |
Data CollectionFind out how you can help V-Ray become better at Chaos Telemetry page. |
End User License AgreementCheck the full legal agreement between Chaos and the end user. |
Silent Install and UninstallFull V-Ray installation without user input during the process using a predefined set of options. |
UninstallHow to Uninstall V-Ray page provides information about V-Ray uninstaller. |
Run V-Ray from an Arbitrary LocationCheck how to run V-Ray from an arbitrary location instead of installing it locally. |
V-Ray App SDKV-Ray Application SDK comes packed along with your V-Ray for 3ds Max installation. |
V-Ray SDKDetailed information about V-Ray SDK can be found at V-Ray SDK page. |
V-Ray for 3ds Max Autodesk application packageDetailed information on the structure of the V-Ray application plugin package. |
