This page provides information on the Bump Material.
The VRayBumpMtl gives the ability to add bump map and normal map effects when using any material.
Simply connect a material into the VRayBumpMtl node to add additional bump or normal map functionality. Stacking multiple VRayBumpMtl nodes together can create a more complex surface material by allowing the use of several bump and or normal maps together easily.
