Coordinates and NoiseCoordinates and Noise are the standard 3ds Max texture rollouts. GeneralThe General rollout holds parameters that control common shader characteristics. Shader file – Specifies the .osl or .oso file which contains the shader (object) code. This button control also supports a context menu with the following options: Clear – Unloads the current shader and restores the plug-in as if no shaders have been loaded. Reset – Reloads the shader and resets its parameters to the default values. Reload – Reloads the shader but keeps the current parameter values. Open Containing Folder – Reveals the shader location in Explorer. Open in External Editor – Opens the shader in an appropriate text editor. Open in Quick Shader – Opens the loaded file's code in the text editor of the Quick Shader. Copy File Path – Puts the full path of the currently loaded file in the clipboard. Copy Folder Path – Copies the parent directory of the currently loaded file into the clipboard. Recent Files – Holds a list of the recently loaded shaders and an option to clear the list. Shortcut Key | Command |
C | Clear | R | Reset | E | Reload | O | Open Containing Folder | X | Open in External Editor | Q | Open in Quick Shader | F | Copy File Path | P | Copy Folder Path | T | Recent Files | 1-0 | The first 10 items of the Recent Files submenu have assigned shortcuts from 1 to 0 |
If you edit your OSL shader, the new version would be loaded only after a Clear, Reset, or Reload option has been selected. Color output – Specifies the color source for the texture's RGB output. If None is selected the texture renders black. Alpha output – Specifies the float source for the texture's alpha output. If None is selected the texture is considered fully opaque. Show preview – Determines whether to render a shader preview in the material editor. Clamp shader result – Determines whether to force the result in the [0, clamping limit] range. Clamping limit – Specifies the upper clamp limit if Clamp shader result is enabled. Wrap texture coordinates – Automatically wraps the texture coordinates for the OSL shader passing only values in the [0.0, 1.0] range. Flip textures – Flips all attached textures vertically for compatibility with 3ds Max OSL Map. Export shader name to OSO – Saves the shader as *.oso file. – Help button which opens a URL provided by the shader.
ParametersAny additional shader – Specific parameters (if any) from the loaded shader file are listed in this rollout. Compiler DiagnosticsThe Compiler diagnostics rollout holds shader compilation and manipulation result messages. |
