Icon text – Enables or disables the display of the VRayPlane text in the viewport. Icon size – Specifies the size of the viewport gizmo in world units. This allows the gizmo to be static, regardless of its distance from the camera, or to be removed altogether. Real-world map size – Enables VRayPlane mapping in actual scale, i.e. it matches the behavior of 3ds Max Real-World Map Size option. This is useful when importing Chaos Cosmos materials which use an actual scale. When disabled, VRayPlane has a fixed mapping in world space. |
