This page provides information about the VRayCoronaScatterMod modifier in V-Ray for 3ds Max.
When Corona 8 is installed and a scene saved with the earlier Corona 7 is opened with V-Ray 6, the scene has its Corona Scatter objects converted to the more advanced Chaos Scatter objects. When Corona 7 is used with V-Ray 6, such scenes keep their Corona Scatter objects and respectively - the VRayCoronaScatterMod. |
When using CoronaScatter object in 3ds Max, you can set up the rendering of the instances by using the VRayCoronaScatterMod modifier.
Note that by default, V-Ray renders CoronaScatter directly. The VRayCoronaScatterMod modifier introduces fine-tuning of the instances.
