This page provides information about the Performance Tab of the Render Setup window when the renderer is set to V-Ray GPU.
The Perf. tab of the Render Setup window contains all performance related settings for V-Ray GPU. You can control the Utilization and Textures settings, or choose which devices to be included in the rendering and also set up Distributed Rendering.
UI Path: ||Render Setup window|| > Performance tab (Renderer set to V-Ray GPU)
Max2024_VRay7_Performance
Rollouts
The Performance tab consists of four rollouts:
Utilization rollout
Adjust parameters concerning shoot rays during rendering (both production and IPR rendering).
Textures rollout
Controls size and resolution of textures with V-Ray GPU rendering.
Distributed Rendering rollout
Set Distributed Rendering settings.
V-Ray GPU Render Devices Select
Easy access to a list of devices to include/ exclude from the rendering process.
