Add server – Click to manually add a server by entering its IP address or network name. Edit server – Click to change data about a render server. Remove server – Deletes the currently selected server(s) from the list. Resolve – Resolves the IP addresses of all servers. Use local host – Determines whether V-Ray runs on the local machine when DR is used. When enabled, V-Ray runs on the local machine as well as on all machines included in the distributed rendering. When disabled, V-Ray does not run on the local machine and instead it only uses the render servers. Use this option when the local machine is needed for other computational tasks. Render region warning/test resolution warning1 – When enabled, V-Ray displays a warning if the render region/test resolution options are enabled before sending a job to the network. By default, the render server machine uses all its graphic cards in CUDA DR rendering, if nothing has been specified beforehand. |
