This render element is enabled through the Render Elements tab of the Render Setup window in 3ds Max and displays its parameters in a rollout at the bottom of the window: VRayVFB – When enabled, the render element appears in the V-Ray Frame Buffer. Color mapping – Applies the color mapping options specified in the Color mapping rollout (Render Setup window > V-Ray tab) to this render element. This option is enabled by default. Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier. Denoise – Specifies whether to denoise this render element. |
