This page gives information about the Velocity Render Element.
A common workflow for using this render element is to first locate the frame in the sequence that has the most motion, render the frame in 3s Max with the Velocity Render Element enabled, and then note the Мax velocity in last frame value, which is displayed in the parameters for this render element. Finally, enter this value (or a slightly larger value) for the Мax velocity parameter when rendering the entire sequence. This workflow provides the maximum range of colors in the Velocity Render Element for the most flexibility during compositing.
The Velocity Render Element is useful for adding motion blur in post production at a composite level, without the need for rendering. See the render before and after compositing.
