This render element is enabled through the Render Elements tab of the Render Setup window in 3ds Max and displays its parameters in a rollout at the bottom of the window: VRayVFB – When enabled, the render element appears in the V-Ray Virtual Frame Buffer. Deep output – Specifies whether to include this render element in deep images. Text alignment – Sets the alignment of the machine name that displays on each bucket. |
