This render element is enabled through the Render Elements tab of the Render Setup window in 3ds Max and displays its parameters in a rollout at the bottom of the window: VRayVFB – When enabled, the render element appears in the V-Ray Virtual Frame Buffer. Deep output – Specifies whether to include this render element in deep images. Color mapping – Applies the color mapping options specified in the Color mapping rollout (Render Setup window > V-Ray tab) to this render element. This option is enabled by default. Multiplier – Sets the overall intensity of the render element, where 1.0 is the standard multiplier. Mode - Controls the way objects are clipped in the element. Normal – Objects are clipped as you would normally see them in the RGB channel. Raw – Three elements are created instead of one: an unpremultiplied RGB element with the object; a floating-point alpha element, and a RGB filter element (includes masking from transparent or refractive objects). GBuf ID – Only objects with this G-Buffer Object ID are considered. IsMATID – When enabled, the pass considers the Material ID and renders accordingly. When disabled, these values are considered to be the Object ID. Invert Selection – Use the opposite of the selected objects in the render pass. Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible. Affect Matte Objects – Sets whether to include matte objects when generating the render element. A matte object is an object that has been assigned a Wrapper Material or VRayObjectProperties with the Matte surface option enabled. |
