When loading a .vrscene in Lavina, it opens the default .vrscene camera. Navigating through the scene, you can save many camera views and go back to them when needed. Go to and press the Save New Camera Slot button in the right corner ( ). A new camera slot from the current view is created, which you can rename. Another way to save a camera is to select an Empty slot and hold the Save Camera button for the drop-down menu to appear. Select the Save This Cam Slot - it saves the currently selected camera view. Then you can rename it. You can always go back to the default scene camera by selecting Home from the drop-down. |
