This page provides information about export .vrscene file with V-Ray for Unreal.
VRayScene allows for assets to be shared between all platforms that run V-Ray.
Exporting a .vrscene
A vrscene from the an Unreal project can be exported with in two ways:
V-Ray toolbar
ІІV-Ray toolbar drop-downІІ > Export vrscene
VRScene Name – Enables the export of a .vrscene file when the V-Ray render button is clicked.
Export VRScene Path – Directory where the .vrscene file is saved. Default directory is <ProjectPath>\Content
Compress – Compresses geometric information thus making the resulting .vrscene file smaller.
V-Ray Bake Settings
Export VRScene – Enables the export of a .vrscene file when the V-Ray Bake  button is clicked.
Export VRScene Path – Directory where the .vrscene file is saved with the file name bake#.vrscene. Default directory is <Project_Path>
Supported Features
Rendering and Light Baking
Cameras
Unreal
  • Camera Actor - Transformations
  • Cine Camera Actor - Transformations
Geometry
  • Static Meshes
  • Blueprint Actors with Static Meshes
  • Foliage
Lights
  • Point Light - Intensity; Light Color; Intensity Units - Unitless, Candelas, Lumens; Source Radius; Temperature; Affects World; Cast Shadows; Use Inverse Squared Falloff; Specular Scale
  • Spot Light - Intensity; Light Color; Intensity Units - Unitless, Candelas, Lumens; Inner Cone Angle; Outer Cone Angle; Source Radius; Temperature; Affects World; Cast Shadows; Use Inverse Squared Falloff; Specular Scale; IES Texture
  • Rect Light - Intensity; Light Color; Intensity Units - Unitless, Candelas, Lumens; Source Width; Source Height; Temperature; Affects World; Cast Shadows
  • Directional Light - Intensity; Light Color; Temperature; Affects World; Cast Shadows; Light Source Angle
Materials
Supported expressions:
  • Constant
    • Constant
    • Constant2Vector
    • Constant3Vector
    • Constant4vector
    • TwoSidedSign
    • VertexColor
    • ViewProperty
  • Coordinates
    • ObjectRadius
    • Panner
    • Rotator
    • ScreenPosition
    • TextureCoordinate
    • WorldPosition
  • Depth
    • PixelDepth
  • Functions
    • FunctionInput
    • FunctionOutput
    • MaterialFunctionCall
    • StaticBool
    • StaticSwitch
  • Material Attributes
    • BreakMaterialAttribute
    • GetMaterialAttributes
    • MakeMaterialAttribute
    • SetMaterialAttributes
  • Math
    • Abs
    • Add
    • AppendVector
    • Arccosine
    • ArccosineFast
    • Arcsine
    • ArcsineFast
    • Arctangent
    • Arctangent2
    • Arctangent2fast
    • ArctangentFast
    • Ceil
    • Clamp
    • ComponentMask
    • Cosine
    • CrossProduct
    • Divide
    • DotProduct
    • Floor
    • Fmod
    • Frac
    • If
    • LinearInterpolate
    • Logarithm2
    • Max
    • Min
    • Multiply
    • Normalize
    • OneMinus
    • Power
    • Round
    • Saturate
    • Sign
    • Sine
    • SquareRoot
    • Subtract
    • Tangent
    • Truncate
  • Parameters
    • ScalarParameter
    • StaticBoolParameter
    • StaticSwitchParameter
    • VectorParameter
    • TextureObjectParameter
    • TextureSample2DParameter
  • Texture
    • TextureObject
    • TextureSample
  • Utilities
    • BumpOffset
    • ConstantBiasScale
    • DDX
    • DDY
    • Desaturate
    • Distance
    • Fresnel
    •  RotateAboutAxis
    • SphereMask
  • VectorOps
    • CameraPositionWS
    • CameraVectorWS
    • ObjectPositionWS
    • PixelNormalWS
    • ReflectionVectorWS
    • Transform
    • TransformPosition
    • VertexNormalWS
Supported Inputs:
  • Base Color
  • Metallic
  • Specular
  • Roughness
  • Emissive Color
  • Opacity
  • Opacity Mask
  • Normal
  • Subsurface Color
  • Clear Coat
  • Clear Coat Roughness
  • Clear Coat Bottom Normal
Supported Blend Modes:
  • Opaque
  • Masked
  • Translucent
  • Alpha Composite
Supported Shading Modes:
  • Unlit
  • Default Lit
  • Subsurface
  • Clear Coat
  • Two Sided Foliage
Supported Material Options
  • Tangent Space Normal
Textures
Texture with Compression Settings:
  • Default
  • Normalmap
  • (plus) NEW - Masks
  • Grayscal
  • (plus) NEW - Displacementmap
  • HDR
  • (plus) NEW - Alpha
  • (plus) NEW - HDRCompressed
Texture Settings:
  • Flip Green Channel
(plus) NEW - Adjustment Settings:
  • (plus) NEW - Brightness
  • (plus) NEW - Brightness Curve
  • (plus) NEW - Vibrance
  • (plus) NEW - Saturation
  • (plus) NEW - RGBCurve
  • (plus) NEW - Hue
Textures with file format:
  • .tga
  • .hdr
Other
  • Sequencer animation with Static Meshes
  • Project packaging/cooking into a standalone application
  • Unreal tone mapper and Post Processes  in viewport rendering
Cameras
  • VRayPhysicalCamera BP
    • Current Camera Settings - Sensor Width, Sensor Height; Focus Method; Manual Focus Distance; Current Focal Length
    • V-Ray Physical Camera Settings - Enable Exposure; 3ds max Compatible; Film Speed(ISO); Shutter Speed S^-1; F-number; White Balance, Reinhard Burn Value; Distortion Type; Amount; Near Clip Plane
Lights
  • VRaySunAndSky BP - On, Azimuth, Elevation, Turbidity, Ozone, Intensity Multiplier, Size Multiplier, Set for Light Bake, Affect Diffuse, Affect Specular
    VRayLightDome BP - On, Use Dome Tex, Dome Tex, Dome Tex Rotation, Dome Color, Intensity, Invisible, Set for Light Bake,  Dome Tex Resolution, Affect Diffuse, Affect Specular, Affect Reflections
  • VRayLightRect BP - Enable, Is Disc, Length/Radius, Width, Multiplier, Cast Shadows, Color, Directional, Invisible, Set for Light Bake, Affect Diffuse, Affect Specular,   Affect Reflections
Materials
Material Instances, V-Ray Material Instances with V-Ray Parent Materials:
  • VRayMtl
  • VRayCarpaintUberMtl
  • VRayPBRMtl
Render Elements
  • Denoiser (NVidia Ai, V-Ray)
  • Background, GI, Lighting, Reflection, Refraction, Specular, Self Illumination, Sub Surface Scattering
  • Diffuse Filter, Reflection Filter, Refraction Filter, Shadows
  • RenderID
  • Normals, Bump Normals, Sampler Info, Velocity, ZDepth
  • Light Select
  • Sample Rate, Unclamped Color, Noise Level
Light Baking
  • Light bake with V-Ray Bake
  • Exporting Lightmaps
  • Importing Lightmaps
