VRScene Name – Enables the export of a .vrscene file when the V-Ray render button is clicked. Export VRScene Path – Directory where the .vrscene file is saved. Default directory is <ProjectPath>\Content
Compress – Compresses geometric information thus making the resulting .vrscene file smaller. NEW - When you export a .vrscene a .bat file is also created with the name specified in VRScene Name and in the directory set in Export VRScene Path. You can use the .bat file to render the exported .vrscene in standalone, outside of Unreal
