This page provides information on the V-Ray Asset Browser, available for 3ds Max 2018 and above. It provides access to the V-Ray Material Library.
V-Ray 5 comes with its own extensive V-Ray Material Library designed to cover detailed resolution for your realistic renders. V-Ray Asset Browser eases navigation in this library by providing high quality material previews, content filtering and quick search in the hundreds of materials available.
||V-Ray Toolbar|| > V-Ray Material Browser
If the material library has not been installed together with your V-Ray 5 this button will download it for you. Once the library is available, it serves to open the V-Ray Asset Browser. |
The V-Ray Asset Browsers consists of a toolbar with quick search and filtering options, a V-Ray Material Library, Preview section, and Favorites section.
A Search bar where you can specifies a filter criteria with wildcards. | |
Filter case sensitivity. | |
Filter by metadata. | |
Sort by name. | |
Opens the material Editor when applying to selection. | |
Specifies thumbnails size. |
