This page provides information on how to uninstall V-Ray using the included V-Ray uninstaller.
The V-Ray installer automatically uninstalls any previous versions before installing a newer version. If you need to manually uninstall V-Ray, please make sure that Houdini or V-Ray components are not being used. For silent uninstallation, see the Silent Uninstall page.
Note that uninstalling V-Ray from Houdini does not uninstall Chaos License Server. It can be uninstalled separately, if needed.
Windows
The Uninstaller originally resides in the following location - C:\Program Files\Chaos Group\V-Ray\Houdini ##.#.###\uninstall
To access the V-Ray uninstaller from the Start menu, search for Uninstall V-Ray Houdini ##.#.###.
This starts the V-Ray uninstaller. Follow the on-screen instructions to remove V-Ray from your system and restore any files overwritten by the installation.
After the uninstall is complete, there may be some leftover files that you need to delete.
Please check if present and delete the following files and folders:
C:\Program Files\Side Effects Software\Houdini ##.#.###\vray
Uninstalling the License Server
To remove the Chaos License Server, either use the Add/Remove Programs applet from the Control Panel or select Windows Start > All Programs > Chaos Group > Chaos License Server > Uninstall Chaos License Server.
Mac OS X
Double-click the Uninstaller.app program, which is normally located in /Applications/ChaosGroup/V-Ray/V-Ray for Houdini/uninstall
Linux
Uninstalling the Plug-In
To uninstall V-Ray for Houdini, start with root permissions the uninstaller program, which is normally located in the /usr/ChaosGroup/V-Ray/Houdini/uninstall/ directory, for example:
$ su
$ /usr/ChaosGroup/V-Ray/Houdini_##.#.###/uninstall/uninstaller
follow the instructions of the uninstaller
$ exit
Note: The uninstaller does not remove the V-Ray license configuration files or any other files that you have modified manually after the installation.
You may need to manually delete the folders:
/usr/sideeffectssoftware/houdini/vray/
To uninstall the Chaos License Server on Linux, start with root permissions the uninstall program, which is normally located in the /usr/ChaosGroup/VRLService/OLS/uninstall/ directory:
$ su
/usr/ChaosGroup/VRLService/OLS/uninstall/uninstaller
$ exit
