This page provides information about the user interface of Chaos Vantage.
Chaos Vantage has a menu row, three sets of toolbars with buttons, as well as left and right panels with several tabs that give you access to a range of functionalities for managing your scene performance and settings.
Click on the highlighted panels to read more about Vantage's user interface components.
.map-area {
  fill: transparent;
  stroke:  rgb(196, 58, 95);
  stroke-width: 2;
.map-area:hover {
  fill: rgba(196, 58, 95, 0.2);
.tooltip {
      position: absolute;
      background-color: #333;
      color: #fff;
      padding: 5px 10px;
      border-radius: 4px;
      font-size: 12px;
      display: none;
      pointer-events: none;
      z-index: 10;
<div class="tooltip" id="tooltip"></div>
 <svg width="1000" height="600">
  <image href="https://docs.chaos.com/download/attachments/60895468/Vantage_Scheme.jpg?version=1&modificationDate=1732775819944&api=v2" width="1000" />
  <a href="https://docs.chaos.com/display/LAV/Menus" title="Menus">
         <rect x="35" y="15" width="960" height="16" class="map-area" data-tooltip="Menus"/>
</a>
<a href="https://docs.chaos.com/display/LAV/Toolbars" title="Toolbar">
         <rect x="233" y="35" width="530" height="26" class="map-area" data-tooltip="Toolbar"/>
</a>
  <a href="https://docs.chaos.com/display/LAV/Left+Side+Panel" title="Left Side Panel">
      <rect x="2" y="36" width="195" height="545" class="map-area" data-tooltip="Left Side Panel" />
  </a>
  <a href="https://docs.chaos.com/display/LAV/Right+Side+Panel" title="Right Side Panel">
    <rect x="803" y="36" width="195" height="545" class="map-area" data-tooltip="Right Side Panel"/>
  </a>
  <a href="https://docs.chaos.com/display/LAV/Animation+Editor" title="Animation Editor">
    <rect x="200" y="543" width="600" height="38" class="map-area"  data-tooltip="Animation Editor"/>
 </a>
  <a href="https://docs.chaos.com/display/LAV/Home+Screen" title="Home Screen">
    <rect x="2" y="15" width="18" height="16" class="map-area" data-tooltip="Home Screen"/>
  </a>
</svg>
<script>
    const tooltip = document.getElementById('tooltip');
    document.querySelectorAll('rect').forEach(rect => {
      rect.addEventListener('mouseenter', (e) => {
        const tooltipText = rect.getAttribute('data-tooltip');
        tooltip.innerText = tooltipText;
        tooltip.style.display = 'block';
      rect.addEventListener('mousemove', (e) => {
        tooltip.style.left = `${e.pageX + 10}px`;
        tooltip.style.top = `${e.pageY + 10}px`;
      rect.addEventListener('mouseleave', () => {
        tooltip.style.display = 'none';
  </script>
Home screen
Detailed information about the Chaos Vantage home screen and the options it contains.
Menus
Detailed information about the menus in Chaos Vantage and the parameters they contain.
Toolbars
Detailed information about the tools available in the Top, Bottom, and the Status toolbars.
Left side panel
Detailed information about the left hand-side panel as well as the tabs it contains.
Right side panel
Detailed information about the right hand-side panel as well as the tabs it contains.
Animation editor
Detailed information about the animation editor.
Command line arguments
Detailed information about the available command line argument for Chaos Vantage.
