Official Release
Date – Mar. 29, 2017
DownloadBuild 3.52.01
New Features
V-Ray
  • Adaptive lights
  • Resumable rendering
  • ALSurface shader support
  • In-Process IPR
  • Glossy Fresnel option
  • Added new Render mask mode: Isolate Selection
  • Support for Interactive Groomable Splines in Maya 2017
  • Implemented AOV callbacks for 2017 Render setup
  • VRayScene node can now use a sequence of .vrscene files and load them automatically on frame change
  • Added integer user attributes
  • Support for negative focus distance values for the V-RayStereoscopic camera
  • Added a switch texture to VRayMultiSubTex
  • Added a checkbox that disables render elements in IPR
  • Added raw filter elements for the diffuse, reflection and refraction channels
V-Ray IPR
  • Added an ability to select scene objects from the VFB window
  • Added an option to select object material directly from the VFB window
  • Added an option to pick focus point by clicking on the VFB window
V-Ray GPU
  • Support for adaptive lights in CUDA (both in production and in IPR)
  • Optimized the V-Ray Material in Maya
  • Support for the directionality attribute of the Rect Light
  • Support for Render ID render element in GPU
  • Support for Render mask
  • Support for matte materials shadow catcher
  • Ability to load precalculated Irradiance Map GI cache files
  • Support for velocity render element
  • Support for Atmosphere render element
  • Support for physical camera distortion
  • Added a low thread priority option
VFB
  • Added Start IPR button to the VFB
  • Added Pause IPR button to the VFB
  • Use Project Path option in V-Ray VFB render history settings
  • Implemented hardware accelerated lens effects
V-Ray GPU / VRayStochasticFlakesMtl
  • Added GPU support
V-Ray GPU / VRayAerialPerspective
  • Added GPU support
V-Ray GPU / VRayClipper
  • GPU support for the planar VRayClipper
Modified Features
V-Ray
  • Speed improvements for the Hypershade material viewer
  • Simplified image sampler options to bucket and progressive
  • No layer token will be added for absolute paths without an explicit token
  • Ability to delete/select VRaySun and VRaySky from the right click menu on the VRay shelf
  • Swatch rendering in parallel
  • VRayMesh file info in the VRayMesh node's UI
  • Print a warning when a texture with color corrections is used as normal map
  • The rollout borders now follow the size of the Render Settings window
  • Adjusted the Quick Settings to account for use local subdivs
  • Faster rendering of particle streaks
  • Support XGen delta files in export
  • Make geometry type in VRay Proxy node keyable
  • Add an option to include render elements in deep files
  • Ptex baker now obeys color clamping controls
  • Post translate python script now supports the new render setup layer overrides
  • Read user/group permissions from home folder when installing with sudo
  • The progressive sampler now finishes the current pass when the given Render time is surpassed
  • Fixed slow compile geometry phase on particular scenes
  • The noise level channel for vdenoise.exe can also be named VRayNoiseLevel
  • Denoiser now doesn't save the extra files when split channels saving is enabled
  • Fallback to %temp% folder for assets transfer if VRAY_ASSETS_CACHE_PATH does not exist
  • Add the ability to abort writing to vrscene files and also print the progress
  • Hint on how to see the vray -help when argument parsing has failed
  • Draw the alpha channel during the undersampling phase of the progressive sampling and V-Ray GPU rendering
  • Support for interpolating geometry data for heterogeneous Alembics with velocity channel
V-Ray IPR
  • More responsive IPR: Abort immediately on scene change
V-Ray GPU
  • Added on-demand texture loading in the GPU
  • Lower CPU memory usage when rendering instances
  • Lower CPU and GPU memory usage when rendering textures
  • Solid reflective material getting alpha dropouts
  • Optimized sampling of materials with bump maps
  • Optimized TexBezier texture
  • Optimized Rounded edges rendering
  • Support the Shadow option of MtlWrapper
  • Support for UVW coordinates type in VRaySamplerInfo render element
  • Native particles systems support (not only from Alembic)
  • Support VRayUserColor to be used for mapping channels
  • Fixed TexLayered not exporting alpha when [Alpha is Luminance] is on
  • Changes on materials with baked texture are going to be reflected quicker
  • Support for Maya projection zoom camera_view parameter
  • Implemented VRayClipper retrace
  • Optimized VDenoise OpenCL version
  • Print a warning that GPU only supports bitmaps in vrayTriplanar
  • Print the OpenCL Driver version in the log
  • Print a warning when max sample level is set to 0
  • Print a warning when there is a render element that's not supported on the GPU
  • Improved GPU utilization when the number of active pixels is too low
VFB
  • The displaySRGB parameter is now exported to .vrscene.
  • Added Reset V-Ray VFB position option to the Show V-Ray VFB shelf button
  • Moved the history image compare buttons from the main toolbar to history toolbar
  • Changed the default values of the Lens Effects
  • Add VFB toolbar button for copying the current channel to clipboard
  • Increase default VFB history maximum files count to 100 and the size on disk in MB to 10000
V-Ray Instancer
  • Improved random by render ID
vdenoise.exe
  • Add abort on OpenCL error for vdenoise.exe
  • Add -verboseLevel option for vdenoise.exe
  • Add -frames option to the vdenoise.exe tool that allows to specify the frames to process
img2tiledexr
  • img2tiledexr now stores its version and build date into the converted OpenEXR files
VRayOSLMtl / VRayOSLTex
  • Enable support for multiple include paths in OSL
VRayScene
  • Hide objects that are not visible directly from camera frustum
  • Redesigned the VRayScene Manager
  • Support for the multiplier parameters under the Additional Surface Properties rollout of the node
  • Follow the displace/subdiv settings
  • Support for light linking
  • Support for the exclude list of the VRayExtraTex render element
  • Support for Subdivs mult in the additional surface properties of the vrscene node
Bug Fixes
V-Ray
  • Fixed missing shadows with motion blurred curves loaded in V-Ray Proxy
  • Fixed static vrscene nodes with animated translations not producing motion blur
  • Fixed Color Correction plugin textures not working as DomeTex
  • Fixed white bitmaps being loaded with channel values greater than 1.0
  • Fixed an error when creating thumbnails using textures mapped to environment variable
  • Fixed a crash when loading a specific .vrscene file with alembic hair
  • Fixed the Light Meter locator not displaying in Viewport 2.0
  • Fixed VRaySun created from Maya Light Lister having no target
  • Light Lister now refreshes on new scene and scene open
  • Fixed wrong UVs with Ornatrix
  • Locking the Enable/Disable light checkbox didn't allow to isolate another light
  • The Strip Paths option now strips paths for included .vrscene files
  • Fixed flickering when rendering with precalculated irradiance map in animation mode
  • Fixed uninverted normal maps not showing as uninverted in DR
  • Cached geometry between renders didn't detect changes to openSubdiv added to displacement node
  • The softMinValue and softMaxValue were not set for shaders created from V-Ray Plugin
  • Fixed a crash with samplerInfo as a material switch and V-Ray Proxy
  • Fixed IPR not working for VRay zip installation with spaces in the folder name
  • Fixed erroneous orange coloration of Render Elements enabled attribute when created on a new render layer
  • Maya image planes now work correctly in IPR
  • Fixed offset controls of ParticleTex UI
  • Removed irrelevant by node handle option from VRayMultiSubTex
  • Fixed error when Maya Assembly loads V-Ray Proxy representation
  • Fixed Ptex baking crash when baking an animation
  • Fixed incorrect dimming of buttons inside the DR settings window
  • Fixed a crash when V-Ray is set as renderer in the Hypershade's material preview
  • Fixed UV offset/distortion with UDIM textures at different camera angles
  • Fixed a crash when changing VRayObjectProperties parameter on a proxy when in IPR
  • Fixed Maya Fluids with Auto Resize having wrong texture mapping when the node is scaled
  • Fixed Maya Fluids with Auto Resize having wrong texture mapping in animation
  • Fixed PTex baking with V-Ray Proxy
  • Support for object visibility flags in Alembic files
  • Fixed ScriptJob getting called in loop on cameraChange event
  • Fixed transmission Parameters for Hair Material getting cut off in UI
  • Fixed tiled TIFF files never getting closed on Windows
  • Fixed post translate python callback value not being saved on close in Maya 2017
  • Fixed warnings when unloading V-Ray in MayaPy
  • Fixed a crash when baking PTex on proxy
  • Fixed proxy GPU preview not redrawing during playback in Viewport 2.0
  • GPU Production mode now takes the correct Brute Force GI Depth value
  • Fixed errors when referencing scene with VRayTexOSL nodes in it
  • Fixed incorrect Motion blur interval center for Alembic animation with changing topology
  • Fixed an error when opening the Ptex options window a second time
  • Fixed new transform node creation for already removed Proxy objects when scrubbing the timeline
  • Fixed wrong shadows with Ptex baking
  • Fixed BRDFVrayMtl rendering black when the refraction color is white
  • Fixed issues when importing VRayFlakes, VRayStochasticFlakes, and Mtl2sided materials from a 3Ds Max .vrscene
  • Fixed BlendMtl not importing correctly from .vrscene file from 3Ds Max
  • Fixed a crash when Hypershade is opened and there is a missing .vrmat file
  • Fixed broken Render mask controls
  • Fixed GI Ray distance slider missing with certain settings
  • Fixed a crash when starting IPR right after Viewport IPR
  • Fixed slow Viewport 2.0 updates when scrubbing the timeline with many proxies (not animated)
  • Fixed XGen cache script error when exporting to .vrscene
  • Fixed a memory leak with Ornatrix for Maya and V-Ray
  • Material preview renderer now pauses correctly when Viewport IPR starts
  • Fixed wrong motion blur with alembic via proxy containing coinciding objects
  • IPR now does not attempt to create folders for saving image output
  • Fixed Ornatrix Hair from Mesh Strips not respecting width settings
  • Fixed strange Motion Blur behavior with alembic files
  • Fixed an exception when rendering a scene with max threads more than physically available
  • Fixed VRayPlaceEnvTex horizontal and vertical rotation parameters not working in batch rendering
  • Missing motion blur on alembic with instanced geometry
  • Fixed a crash when subdividing proxy and wrong merging of mapping channels
  • Support drawing new XGen Interactive Groomable Splines with V-Ray materials in the viewport
  • Fixed separate export of vrscenes for materials, textures, and bitmaps when exporting the nodes wasn't checked
  • Fixed a crash and wrong renders with animated proxy and CUDA
  • Fixed a crash when creating frame expression as switch texture for MultiSubTex
  • Ornatrix UV coords were not exported sometimes
  • Fixed a crash on executing the vfbControl command with "-historycomment" argument
  • Added an option to get RenderElements names from their node names
  • Fixed scheduling issues and lockups on machines with groups enabled
  • Exporting vrscene to separate files will not be allowed with DR
  • Fixed non existing paths not being created relative to the project path on Linux and OSX
  • Fixed some machines not loading IFL files when accessing them from shared location
V-Ray GPU
  • IPR didn't start if the frame is negative
  • Fixed missing alpha pixels with matte/shadow plane
  • Fixed fatal error when baking multiple objects with CUDA
  • Fixed overexposed lighting when rendering with V-Ray GPU
  • Fixed the specular contribution not getting adjusted by the fog attenuation
VRayScene
  • Fixed override data is not obtained by third-party plugins
  • Fixed Object ID override not working with VRayScatter
  • Override by type now doesn't mask override by name
  • Fixed Instancer from vrscene not being visible
  • Fixed set new material on Node not working
  • Fixed crash with Node without material
  • Fixed Node override info being stored only for first VRayScene instance
  • Multiple <*> patterns are now handled correctly
  • Maya's project path is now taken into account
  • Lights are now cloned for all instances
  • Fixed a crash with VRayScatter inside
  • Fixed animation overrides not working for loop mode
  • Fixed per particle rgbPP attributes on Instancer not rendering from a VRayScene node
  • Fixed the VRayScene node axis getting reset to 0,0,0 if Animation Overrides are enabled
  • Animation overrides were affecting the preview animation without Use Animation Overrides being active
  • Fixed GeomPlane not rendering
  • VRaySun and domeLight with texture have incorrect up vector
  • Fixed override by name
  • Overwriting a texture with another one using snippets was fixed
VRayProxy
  • Fixed errors when loading a referenced scene with a VRayMesh without a preview node
VFB
  • Fixed Maya 2017 using 100% of 1 core when the VFB window is opened
  • Changing channels in VFB while docked and rendering is now possible
  • Fixed VFB region changing its position if Viewport IPR is started
  • Fixed vertical lines appearing in VFB when comparing rendered images
  • Fixed history Settings dialog being inaccessible for some desktop configurations
  • The Close button on the History settings window was not clickable
  • Fixed overlapping slider and components in the CC window
  • Fixed the VFB not respecting the VRAY_VFB_LUT_FILE env variable
  • Fixed apparent moving of a point in the curves color correction window
VRayClipper
  • Fixed artifacts with mesh as clipper
  • Fixed crashes with animated clipper with motion blur after rendering the first frame
  • Fixed bright pixels in the Specular render element with stochastic flakes material
VRayDirt
  • Fixed black Viewport 2.0 preview with VRayDirt
Texture Baking
  • Displacement and subdivision are now respected when baking on point clouds
VRaySwitchMtl
  • VRayUserInt texture didn't work correctly with the VRaySwitchMtl material
VRayVolumeGrid
  • Fixed Maya fluids not generating emissive lights
img2tiledexr
  • Fixed broken file conversion to EXR
