The Refraction Render Element stores refraction information calculated from materials – such as glass or water – that refract objects behind them in the camera's view. This means the brightness, coloration, etc. of the refractions can be adjusted without the need to rerender. Any material in a scene that has a value set for its Refraction parameter will generate refraction information that can be seen in this render element. A surface with no refraction values set in its material(s) will contain no information in the render element and therefore render black. The Refraction Render Element is a key component in the main Beauty Element and can easily be used to control the refractions in the Beauty composite. The Refraction Render Element itself is already a composite of the vrayRE_Raw_Refraction render element multiplied by the Refraction Filter render element. When finer control over refractions is needed in the composite, add these additional two channels to the output along with the vrayRE_Refraction render element channel. To use render elements, select from the Available render elements column and click the Add button to add the passes you wish to generate at render time. When you render the scene, the added render elements listed in the column on the right, will also render, which can be viewed from the VFB window's channel drop-down menu. For more information on the parameters on this dialog, see the Render Elements tab page. |
