Switch – The texture which is sampled to switch between the assigned materials Material 0 - Material 9 – Materials to be used based on the value of the the switch texture. Material 0 is assigned for values 0 - 0.499 Material 1 is assigned for values 0.5 - 1.499 Material 2 is assigned for values 1.5 - 2.499 Material 3 is assigned for values 2.5 - 3.499 Material 4 is assigned for values 3.5 - 4.499 Material 5 is assigned for values 4.5 - 5.499 Material 6 is assigned for values 5.5 - 6.499 Material 7 is assigned for values 6.5 - 7.499 Material 8 is assigned for values 7.5 - 8.499 Material 9 is assigned for values 8.5 and larger. |
